When I use the Default Search I am seeing some strange behaviour with routing, with the issue being that most of the search options result in a 404. I can see the problem is that the search is routing to URLs that include the WP installation folder vs the site address URL.
The odd thing is that this does not occur if I select Collections as the search option. Below are the examples of the URL it tries to route to:
- Collections; Search Results for “clive” – Charlton Atheltic Museum (works)
- Global; https://cafcmuseum.net/web/?s=clive (404 as puts in folder) - correct URL would be Search Results for “clive” – Charlton Atheltic Museum
- Posts; https://cafcmuseum.net/web/?onlyposts=true&s=clive (404)
- Pages https://cafcmuseum.net/web/?onlypages=true&s=clive (404)
- Items https://cafcmuseum.net/web/items?search=clive (404)
I have tried turning off cache plugins, re-saved Permalinks, updated .htaccess as per WP guidance but no luck.
Is this a bug or am I missing some config somewhere?
