Perpage url parameters not being obeyed
?view_mode=cards&perpage=48&paged=3
This ignores the 48 and does 12. This is especially an issue when navigating back and forth between the archive and an item as it does not return to the same place you clicked from.
The more per page only works when you click it from the dropdown on page
Hi @Aaron!
Thank you for bringing this up, it is indeed a bug, I’ve opened an issue:
We’ll take a look at it soon.
1 curtida
Hey @Aaron I forgot to warn you but the latest release (version 0.21.7) should have fixed this. Can you validade it for me?
Well, it does not show 48 in the url and only show 12 records now…
instead it just redirects to putting 12 in the url.
https://lefaucheux.com/archives/?view_mode=cards&perpage=48
instantly redirects to:
https://lefaucheux.com/archives/?view_mode=cards&perpage=12&paged=1&order=DESC&orderby=date&fetch_only=thumbnail%2Ccreation_date%2Ctitle%2Cdescription&fetch_only_meta=
Do you have any caching plugin enabled? Or even a cdn, server level cache? If so, could you try clearing it? My attempts to access the link actually ended up in an error…
