Some issue seems to have happened recently where images are not uploading right. It may be an issue with the redirect setting for the x folders?
It is looking in the correct, non x, folder:
(could not put more than 2 images)
and the file does exist:
Same issue on attachments:
When I publish it as public it does work, but if I publish it as draft or private the images dont show up.
Also, was having weird issue if I publish it first as draft and then change to public it wasn’t working right either.
