After the last update, I thought I had solved all the issues, but one remains, and it’s quite significant. I’m using the Faceted Search block and selecting items for display using taxonomy. However, when I click and navigate to the item page, the navigation at the bottom doesn’t work or behaves erratically (it used to work fine before).
Instead of navigating within the selected taxonomy, the next image (next postcard) starts from the beginning of the entire repository. What’s even stranger is that if I exit the item page, browse through that set of items as a slideshow, and then return to the item, everything works fine.
I’ll try to illustrate this with screenshots.
However, as soon as I change location, I encounter the same problem again—meaning that entering the slideshow only seems to fix the issue temporarily. I have cleared all caches.
Here are the links, but the order doesn’t work correctly on any of the pages.
It seems that navigation is always navigating from the first taxonomy, second item from the first taxononomy in whole repository.
Hi @Vedran_Serbu!
Changing to slideshow shouldn’t have a great impact here since that component does not reload the page itself… but the rest of the behavior is indeed incorrect. I’ll have to take a time to investigate, but my bet is that this sort of dynamic navigation link won’t work when coming from the Faceted Search block instead of a default theme template… But maybe it is something solvable. I’ll give it a try as soon as I can!
Thank you Mateus, it worked before so I hope it is just some kind of bug
Luckly we are bout to release a new version and had time to include this fix in the RC that is being prepared. If you want/can git it a try…
It should be fixed, let me know in case you find anything weird.
Unfortunately, nothing changed.
I installed new version. Cleared cache, disabled cacheing from Cloudflare so it is in development mode.
Should I completly uninstall Tainacan and install new version?
I suspect that you are still suffering from some caching… because right now if I access that same link it works:
Now it works for me too! Once again, you’re a life saver!
Thx Mateus, and to all your team!
