Hi! After the last update, I can’t insert text normally in the text metadata type field, it’s tricky, letters jumping. Other types of fields working fine. I tested this on various systems and made a comparison to the previous version of Tainacan, where everything is fine. Please help.
Hi @YuriShkoda!
I’m sorry that you are experiencing this. This bug was reported a few days ago, while we have fixed it in development, the final release is not published yet. You can download this dev version or wait a couple days more, we’re working to finish it:
Just remember, when testing versions updated like that to reload your browser cleaning the cache after update (CTRL+SHIFT+R).
Thank you! The highest level of support, as always!
