Batch import - question
Hi, another question about batch import.
When importing images using batch import, the title of each item is automatically generated from the name of the image, for example, ‘this_is_imported_image.jpg.’ Is there a way to create the item title without including the file extension, so that the .jpg (or .png, or any other extension) is omitted from the automatically generated title?
Hi @Vedran_Serbu!
Unfortunately not, we don’t have an easy solution for that. My suggestion would be to later export your collection via CSV exporter, tweak all the titles as you prefer in a spreadsheet and re-import them using the update option of the CSV importer. You would only need the special_item_id and title columns to do the update.
