I’d like to report a bug. When I try to edit items in sequence, I always get the same item image as attachment (first image in sequence is shown for all items as attachment). It seems that it is only a bug that do not interfere with real attachment because when I check the item outside “sequence editing” I get the real image, but it is a bit confusing.
Uhmmm thanks for bringing that up @Vedran_Serbu, it seems possible. I’ll take a look at it tomorrow!
Oi, também acontece comigo
Hey @Vedran_Serbu and @marinacdarosa this should be fixed in the next release. Here you can give it a try if you need it right now:
Thanks for bringing that up!
