Hello:
I am using Tainacan plugin version 0.21.12. It seems that, since the update, CVS exporting gets stuck. It does not show any progress and does not finish. In the exporter folder, I find multiples files, every five minutes, containing the first 96 records of the collection (see figure). I installed WP Cron (see figure). How do I solve this?
On the other hand, I am getting a critical error when personalizing a page with Blocksy Premium versions above 2.0.76. It works with version 2.0.76.
Thank you in advance,
Pedro
Can you check if this same error happens with this version of the Tainacan Support plugin? I was just the other day looking at it:
Regarding the export process, if you use WP Crontrol to force the execution of the Tainacan related process, does it do something?
Dear Mateus:
The new tainacan blocksy plugin solved the problem. Thank you
However, I am still having problems with the CSV exporter. I forced the process to no avail. It stays at 0% progress for a small collection (170 registers)
Best regards,
Pedro
Dear Mateus:
My CSV exporting problems continue. Any other ideas?
Best regards,
Pedro
Hi @argeifontesfunes
Could you show us how the WordPress site’s health check is looking?
Did you have a try executing the steps described in this topic:
