Tainacan warnings "deprecated"
Following a ticket with Blocksy support, they pointer out that Tainacan is generating many warnings (warnings. Is this something I should be worried about?
Best regards,
                    Pedro
Hi @argeifontesfunes
This is probably a problem with the PHP version. Tainacan does not support php8, I recommend using php 7.4.
we are working to migrate to php8
att
Thank you for your help. I will stick with the current versión of php and wait for Tainacan’s update.
Best regards,
                    Pedro
