Good afternoon,
In my collections, the metadata is no longer displayed in the metadata overview or on the item page.
I have tried with different users and different rights
However, the data is still displayed in the item pages and in the
item overview, which means that it is still in the database.
Do you have any idea what could be causing this?
Kind regards
Christian
Hi Christian, welcome to our forum ![]()
This is really odd, but we’ll see if we can figure out what is going on. My first attempt would be to ask you show us your console logs and network logs at the moment that you enter this page. Here you have some guidance on how to get those:
But I’m also curious on why are your tabs blue like that… do you have any plugin activated that could be causing this css conflict?
Hi Mateus,
you made my day.
The problem was actually caused by a plugin called QR Code Composer. After I deactivated it, the metadata are visible again and the tabs are no longer blue.
Thanks a lot
Kind regards Christian
No problem, thank you for the report. I’ll open an issue in their forum to let they know that their code is causing style conflicts, it is an issue simple to solve actually.
