Hi Team,
Whats the general system requirements recommendation?
Like in Digital Ocean droplets, Should one focus on RAM or CPU mostly?
1 curtida
Hi @kasscomplex, welcome to our forum!
So this is a tricky question, because it depends a lot on the data of your archive. It can be impacted by the amount of items x metadata that you have. @vnmedeiros can you help me answer this one?
Hi @kasscomplex
This question does not have an exact answer, as it will depend on the use of the installation, average number of accesses, size of the repository, size of documents that will be stored on the server, etc.
You can find the requirements for wordpress here:
in my experience, for small to medium installations you have 4Gb of RAM and 4 cores already fulfills a good amount of server requests
