Block Tainacan List of Terms
Hi
I used the Taincan List of Terms block on a page. My expectation was that the picture of the term is shown in the block.
Did I miss a setting?
Hi @ralfh!
Actually no, this was supposed to work… Are you sure this is the same Taxonomy? I’ve just did a quick test here and it works…
Also don’t forget to give a try on another block called “Facets list”.
With Facets List, you can do something like this:
That will require some options tweaked:
The catch is to Select an ascending (parent) term and define it as the root one. Then toggle the option to Attach descending (child) terms. I’ve also played a bit with the way the Facets label is displayed and the amount of columns displayed.
