image_editor: WP_Image_Editor_Imagick
imagick_module_version: 1809
imagemagick_version: ImageMagick 7.1.1-47 Q16-HDRI x86_64 22763 https://imagemagick.org
imagick_version: 3.8.0
file_uploads: 1
post_max_size: 64M
upload_max_filesize: 64M
max_effective_size: 64 MB
max_file_uploads: 20
imagick_limits:
imagick::RESOURCETYPE_AREA: 470 GB
imagick::RESOURCETYPE_DISK: 9.2233720368548E+18
imagick::RESOURCETYPE_FILE: 393216
imagick::RESOURCETYPE_MAP: 235 GB
imagick::RESOURCETYPE_MEMORY: 117 GB
imagick::RESOURCETYPE_THREAD: 1
imagick::RESOURCETYPE_TIME: 0
imagemagick_file_formats: 3FR, 3G2, 3GP, A, AAI, AI, APNG, ART, ARW, ASHLAR, AVCI, AVI, AVIF, AVS, B, BAYER, BAYERA, BGR, BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, C, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CR3, CRW, CUBE, CUR, CUT, DATA, DCM, DCR, DCRAW, DCX, DDS, DFONT, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FARBFELD, FAX, FF, FFF, FILE, FITS, FL32, FLV, FRACTAL, FTP, FTS, FTXT, G, G3, G4, GIF, GIF87, GRADIENT, GRAY, GRAYA, GROUP4, GV, HALD, HDR, HEIC, HEIF, HISTOGRAM, HRZ, HTM, HTML, HTTP, HTTPS, ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, J2C, J2K, JBG, JBIG, JNG, JNX, JP2, JPC, JPE, JPEG, JPG, JPM, JPS, JPT, JSON, K, K25, KDC, LABEL, M, M2V, M4V, MAC, MAP, MASK, MAT, MATTE, MDC, MEF, MIFF, MKV, MNG, MONO, MOS, MOV, MP4, MPC, MPEG, MPG, MPO, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, O, ORA, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PGX, PHM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, POCKETMOD, PPM, PS, PS2, PS3, PSB, PSD, PTIF, PWP, QOI, R, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGB565, RGBA, RGBO, RGF, RLA, RLE, RMF, RSVG, RW2, RWL, SCR, SCREENSHOT, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, SRW, STEGANO, STI, STRIMG, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TM2, TTC, TTF, TXT, UBRL, UBRL6, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBM, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, Y, YAML, YCBCR, YCBCRA, YUV
image_format_transforms: image/heic → image/jpeg, image/heif → image/jpeg, image/heic-sequence → image/jpeg, image/heif-sequence → image/jpeg
gd_version: 2.3.3
gd_formats: GIF, JPEG, PNG, WebP, BMP, XPM
ghostscript_version: 9.54.0
He conseguido arreglarlo creando un «parche»: un plugin que relaciona las imágenes cargadas previamente en la biblioteca de medios con los elementos de Tainacan y las importa. Funciona, però se tiene que ejecutar como una tarea adicional: no es ideal, vaya.
Para vuestra información y por si os es útil de alguna manera, estoy utilizándolo para hacer una propuesta de archivo fotográfico municipal para mi ciudad, Calella en la provincia de Barcelona, España.
Este es el sitio de «staging» donde estoy haciendo pruebas ¡y aprendiendo Tainacan! (en catalán):
