I’m having a hard time trying to do this. It seems that it is not an option through the plug-in. The required* settings are only available for metadata properties.
Already fixed with the code below:
function tainacan_document_required() {
<script>
document.addEventListener("DOMContentLoaded", function () {
const observer = new MutationObserver(function () {
const submitBtn = document.getElementById("tainacan-item-submission-block-button--submit");
if (submitBtn && !submitBtn.dataset.listenerAdded) {
submitBtn.dataset.listenerAdded = "true";
submitBtn.addEventListener("click", function (e) {
const docSection = document.getElementById("tainacan-item-metadatum_id-document");
const uploaded = docSection && (
docSection.querySelector(".file-name") ||
docSection.querySelector(".tainacan-file-name") ||
docSection.querySelector("img") ||
docSection.querySelector(".upload-item") ||
docSection.querySelector("a")
if (!uploaded) {
e.stopImmediatePropagation();
alert("Please upload a document before submitting.");
}, true);
observer.observe(document.body, { childList: true, subtree: true });
</script>
<?php
add_action('wp_footer', 'tainacan_document_required');
Just put it in the functions.php.
Hi @djafinidad!
This is an interesting request. I’ve opened a new issue for it:
The solution that you offered is a good workaround for the Item Submission Block but I believe we should have it somehow configurable for all item edition forms. We will take a look at this in the future!
