Line break problem
Hi. I have the problem that I am not respecting the line break. Any suggestions on how to fix it?
thanks
brave_LGxd8Bw0Ke
Hi @abraxas. Could you send me a link for the public page of this item? This should be easily fixed via css, I just have to make a few tests.
[escribe o pega el código aquí](https://redescubramossonora.mx/repositorio/plano-de-la-colonia-de-torim-suelo-agricola/)
Thanks!
So a quick solution would be to go into your theme settings, under Appearance → Custom CSS and add this line:
.tainacan-item-single-page .tainacan-item-single .metadata-type-textarea {
     white-space: pre-line !important;
I would have to take further investigation to see if I should add this to the plugin itself, but this should fix your case.
thanks for your help… your solution only fixes the “Descripción física” field. the “Descripción” and "Procedencia
procedencia
" fields still appear without the line break.
any idea how to fix it? thanks
Yes! Sorry, this should do the trick:
.tainacan-item-single-page .tainacan-item-single .metadata-type-textarea,
.tainacan-item-single-page .tainacan-item-single .metadata-type-core_description {
thank you very much Mateus for your help and patience! it worked perfect! cheers!
