Hola. Espero que todo el mundo esté bien.
¿Sería posible un widget que presentara algo así como el ítem del mes (o de la semana…), seleccionado aleatoriamente o de forma manual?
Gracias.
I feel like this feature would be better handled by some WordPress plugin. There are numerous targeting posts display (like a random selection of posts every time the user access a page). And any block/widget that works for posts may be set to display Tainacan Items, as they are, in the inside, just Custom Post Types
Now, I must admit I’ve never used one with this particular setting (random selection, but just change at the beginning of the Week/Month), but I also haven’t tried out many so far.
. If you or anyone happens to know it, we could discuss integration or maybe a feature request for the plugin developers.
